Can the DacMagic Plus / Stream Magic 6 / 851D / 851C act as USB to SP/DIF convertors for lossless and high resolution material?
The USB input of the  DacMagic Plus / Stream Magic 6 / 851D / 851C is automatically broadcast over the coaxial digital output which allows you to use either as a USB-SP/DIF interface if required.
