Is there anything I should have, or do, prior to setting up my Minx Air?
If you plan on using iTunes to stream music via Airplay from your computer, please ensure you are running the latest version of iTunes.
If you plan on using Airplay to stream music from an Apple iPhone or iPad, please ensure that the device's firmware is up to date.
Have your home Wi-Fi network name (SSID) and password written down or handy as you will need this information to successfully set up the Minx Air.
If you are intending to control your Minx Air with an Apple or Android smart phone or tablet, please download the free Minx Air app from either the Apple App store, or the Google Play store respectively.
Android smart phones/tablets must be running Android version 3.0 or later to run the Minx Air app.
