How do I connect my Minx Air to a network using a permanent wired network connection to my home network/router?
Disconnect the power cable from the rear of the Minx Air and connect an Ethernet cable between the router and the Minx Air, an Ethernet cable should be included in the box with your Minx Air.
Next, reconnect the power cable to your Minx Air and press the power button to turn on the product.
After several seconds, the WPS light on the rear of the Minx Air should now be a solid green colour - this indicates that a wired network connection has been established, and the Minx Air should be ready to use with Airplay and internet radio.
1 out of 1 found this helpful
