How do I connect my Minx Air to a different network if my network has changed, or if I move house or change my router?
When you set the Minx Air up for the first time, you will connect it to your home network.  If you wish to connect it to a different network, then you can do this in three different ways:
  • By Pressing and holding the WPS button on the rear panel of the Minx Air for 7 seconds. The light on the rear panel will flash Green > Orange. Now go to Step 2 in the WiFi setup guide provided with the Minx Air.
  • By connecting to the new network using WPS as detailed
  • By carrying out a factory reset of the Minx Air as detailed
  • Now go to Step 1 in the WiFi setup guide provided with the Minx Air.
Note: carrying out a factory reset will also erase any internet radio station presets and other preferences that you may have stored.
