Can I use the 551R, 651R and 751R in a six channel configuration?
The Cambridge AV receivers are principally designed to operate in either 5 channel or seven channel modes but can support a six channel speaker configuration if required. To do this, you should run the auto setup in the five channel configuration before switching to 7.1 and manually adding distance and level information for the surround back left speaker.
