840A/C IR Codes
840C CD/amp
System Code = A0 A0          (NEC Code)
Key         Command Code (hex)
1              01
2              09
3              11
4              19
5              02
6              0A
7              12
8              1A
9              03
0              0B
1+           13
Prog        1B
Play         15
Pause     1D
Stop        1C
Random 0E
Remain   0F
Skip left  04
Skip right               0C
Repeat   16
AB           17
<<           05
>>           0D
Intro       06
Space     1E
Open      07
Power toggle        44
Power On              46
Power Off              45
Bright toggle         47
Menu     48
Select     49
Mute      4A
Mute on 4B
Mute off                4C
Also incorporates  Amplifier codes
System Code = 16                (RC5 Code)
Key         Command Code (dec)
Aux/Phono            4
CD           5
Tuner/DAB            3
DVD        1
AV/MD   2
Tape Mon              0
Source 7                6
Source 8                7
Vol -        17
Vol +       16
Mute      13
Amp on  14
Amp off  15
Standby toggle      12
Mute on 50
Mute off                51
Speaker Select     20
Mode     21
Bright     18
Source Up             8
Source Down        9
Clipping Off           10
Also incorporates iPod commands
System Code = EE 87           (NEC Code)
Skip back               08
Play/pause            04
Skip forward         07
Menu (stop)          02
