What are the remote control command codes for a 640T, 540R, 640C & 540D?
Azur Products Remote Control Command Codes
640T DAB/FM/amp
System Code = 17                                (RC5 Code)
Key         Command Code
Power  (not used on azur remote)   124
Brightness             71
Auto Tune             117
Mute (not used on azur remote)      116
Preset 1 91
Preset 2 92
Preset 3 93
Preset 4 94
Preset 5 95
Preset 6 96
Preset 7 97
Preset 8 98
Preset 9 99
Preset 10               100
Scroll up                77
Scroll down           78
Select     87
Info         121
FM/DAB 101
Alarm     125
Multi-Room Specific Extensions
Power On (used on azur remote)     102
Power Off (used on azur remote)     103
Mute On (not used on azur remote)                104
Mute Off (not used on azur remote)                105
Preset Up (not used on azur remote)              106
Preset Down (not used on azur remote)         107
DAB   (not used on azur remote)      108
FM     (not used on azur remote)      109
Also incorporates  Amplifier codes
System Code = 16                (RC5 Code)
Key         Command Code
Aux/Phono            4
CD           5
Tuner/DAB            3
DVD        1
AV/MD   2
Tape Mon              0
Vol -        17
Vol +       16
Mute      13
Standby on            14
Standby off            15
540D DVD Player
System Code = 07 F8           (NEC Code)
Key         Command Code
Open Close           43
Power    01
Audio     15
Sub         54
Angle      55
OSD        46
Zoom      57
Keyboard               4F
Repeat   0E
A-B          0F
PAL/NTSC              07
I-Scan     04
Logo       1A
P-Scan    06
Title        19
Info         05
Menu     5B
              59
<              58
>              5E
              5C
Select     5D
Setup      1D
Pause     16
Return    5F
Skip left  0B
Play         14
Skip Right               4A
<<           08
Stop        17
>>           0A
Vol +       56
Vol -        52
Slow        10
Mute      13
640C CD/amp
System Code = A0 A0          (NEC Code)
Key         Command Code
1              01
2              09
3              11
4              19
5              02
6              0A
7              12
8              1A
9              03
0              0B
1+           13
Prog        1B
Play         15
Pause     1D
Stop        1C
Random 0E
Remain   0F
Skip left  04
Skip right               0C
Repeat   16
AB           17
<<           05
>>           0D
Intro       06
Space     1E
Open      07
Power On              46
Power Off              45
Key         Command Code
Aux/Phono            4
CD           5
Tuner/DAB            3
DVD        1
AV/MD   2
Tape Mon              0
Vol -        17
Vol +       16
Mute      13
Standby on            14
Standby off            15
540R  Receiver
System Code = C0 C0 (NEC Code)
Key         Command Code
Input select           05
Power    0C
Input mode           60
6.1 direct               0F
Stereo    1A
PLII          02
DD EX /DTS ES       17
Surround mode    09
Dynamic 13
LFE trim  20
Test Tone               07
CH select               0D
Sub on/off             12
Vol +       03
Tune -     06
Mute      14
Tune+     15
Vol-         1F
+              0B
Bass        11
SPK setup              01
-               19
Treble    0A
Delay      A0
Mode     1E
Stereo /Mono       0E
Store      1D
FM/AM  1C
PTY          16
APS         1B
Display   04
