The 640T/651T/One takes its time signal from FM RDS broadcasts. If you do not have a very strong FM RDS signal, then the unit will not be able to lock onto the time, and the time/alarm function may not work properly. If this is the case, you may require a larger FM aeriel or signal booster.
