Why is my 740A not responding to the remote control?
If you find the 740A isn't responding to commands from your remote control, after changing the batteries, please check the set of 4 dip-switches on the rear panel of the 740A. If these are set incorrectly they will disable the remote control receiver in the front panel.
If these switches have been moved or knocked, ensure that the switch marked 'Front Panel IR' is set to the 'On' position.
