How do the record outputs on my AV receiver work?
The Record outputs on Cambridge Audio AV Receivers will only output a signal in the same format it is received in. If an input is digital (optical or coaxial), this will only be outputted by the digital outputs, and if a source is analogue, this will only be outputted from the analogue outputs.
On the 640R/650R, the signal sent to the REC 2 output must be selected in the On Screen Display.
The Pre-outputs will output whichever source is currently selected, irrespective of whether this is analogue or digital.
