Where do I earth my turntable on my Cambridge Audio amplifier?
Cambridge Audio amplifiers (with the exception of the Topaz AM10 and SR10) do not have a phono stage built in. As a result none of the amps are now fitted with a turntable earth. Both the 540 and 640P phono stages have an earth for this reason. If you are using another manufacturers phono stage that is not fitted with an earth, you will need to consult with the turntable manufacturer for earthing options.
