My cartridge has a lower rated output than the 540P/640P or 551P/651P is specified to work with. eg. My new cartridge has 0.25mV output and my 640P is rated at 0.5 - 1.0mV. Will this work?
Yes, this will be fine.
If your cartridge has a lower output you will simply get a lower resulting output from the 640P and will consequently just need to turn the amplifier volume up slightly to compensate for this.
This does not cause the amplifier to work harder, it just means that you may need to adjust the volume back down when switching to a different input such as CD.
