I cannot get the receiver to process or display Dolby TrueHD or DTS-HD Master Audio. I have a HDMI cable running from my Blu-Ray player to the 650R and another HDMI from the 650R to the TV.
You must make sure that the HDMI audio output from the Blu-ray player is set to 'raw/bitstream' rather than 'PCM'.  Raw/bitstream will allow the BD player to output the raw HD audio soundtrack to the 650R for decoding.
Also, many Blu-ray discs dont actually have a Dolby TrueHD or DTS-HD Master Audio soundtrack on them.  Instead, they often just have a regular DD or DTS soundtrack, so it is worth checking the actual discs for the soundtrack type.
