Connecting iD100 to a DAC. Is it possible to connect the iD100 to the 851C / 851D / Stream Magic 6 / 740C / 840C / Minx Xi DACs?
Yes, you can certainly use one of the digital inputs on any of our DACsr to connect the digital output from the iD100.  This way, the raw digital signal from the iD100 would then be up-sampled by the CD player and the best possible sound would be obtained from your iPod/iPad/iPhone.
Additionally the 851C and 851D have a balanced AES/EBU input allowing you to connect an iD100 via the AES/EBU output for the best possible sound
