Can I use my Azur DacMagic to play high resolution audio from my computer? The USB cannot receive files larger than 48kHz.
The original DacMagic (2008 - 2011) has an older USB connection which can only receive a maximum of 16-bit/48kHz files. But the other inputs are able to receive files of up to 96kHz.If your computer can output an optical or coaxial connection, you can connect to a DacMagic.
The DacMagic XS, DacMagic 100, DacMagic Plus, Stream Magic 6, 851D, 851C and 751R all feature a much newer USB connection will allow playback of files up to 24-bit/192kHz.
You can also play up to 24-bit/192kHz files through the optical/coaxial input sof these newer DACs.
3 out of 3 found this helpful
