Do I need an internet connection to use the Minx Air?
You can use the Minx Air without an internet or network connection to play back audio from Bluetooth sources or from the analogue input.
You must connect the Minx Air to a network to use Airplay, but this does not necessarily require an internet connection.
You must connect the Minx Air to a network and must have an active broadband internet connection to be able to listen to internet radio.
Use of a network and a broadband internet connection is highly recommended.
