Does the Minx Air have a factory reset?
Yes, to reset the Minx Air, press and hold the Power button (on top of the unit) and the WPS button (on the rear panel) together for 10-15 seconds. Once the back LED light turns amber release both buttons and turn the Minx Air back on.
Warning: carrying out a factory reset will erase any stored presets, preferences and network connection details, all of which will need to be re-entered when you restart the Minx Air.
