How many Minx Air devices can I use on my network at the same time?
You can connect as many Minx Air units to your home network as you wish.  However, the Minx Air app will only talk to one unit at a time, so you will need to manually switch between units on the app (using the Devices option within the app) to control each Minx Air speaker as required.
