640T IR Codes
640T DAB/FM/amp
System Code = 17                                (RC5 Code)
Key         Command Code
Power  (not used on azur remote)   124
Brightness             71
Auto Tune             117
Mute (not used on azur remote)      116
Preset 1 91
Preset 2 92
Preset 3 93
Preset 4 94
Preset 5 95
Preset 6 96
Preset 7 97
Preset 8 98
Preset 9 99
Preset 10               100
Scroll up                77
Scroll down           78
Select     87
Info         121
FM/DAB 101
Alarm     125
Multi-Room Specific Extensions
Power On (used on azur remote)     102
Power Off (used on azur remote)     103
Mute On (not used on azur remote)                104
Mute Off (not used on azur remote)                105
Preset Up (not used on azur remote)              106
Preset Down (not used on azur remote)         107
DAB   (not used on azur remote)      108
FM     (not used on azur remote)      109
Also incorporates  Amplifier codes
System Code = 16                (RC5 Code)
Key         Command Code
Aux/Phono            4
CD           5
Tuner/DAB            3
DVD        1
AV/MD   2
Tape Mon              0
Vol -        17
Vol +       16
Mute      13
Standby on            14
Standby off            15
