Will digital pre-amp mode reduce the audio quality of the NP30?
The signal resolution and audio quality will not be reduced or degraded if using the optional digital pre-amp mode.
We use a system to alter the volume level without degrading the audio quality and this implemented by the upsampling circuit within the units Digital-to-Analogue converter
or of the DSP's algorithm's output, hence noise performance at lower levels is mainly limited by the DACs.
