How can I connect my streaming service to the Azur 851N?
 Spotify Connect
Cambridge Audio network players include the Spotify Connect service which allows you to play your music directly from the network player and using the Spotify app as a remote control.
Select “Devices Available” from within the Mobile or Desktop app and choose the Cambridge Audio network player on the same network to take advantage of this feature.
Compatible Streaming Services: Spotify Only
 Apple AirPlay
You can play any streaming service on your network player using AirPlay from a compatible Apple device.
Choose “More Devices” and select the Apple AirPlay icon  from within your chosen App, Control Centre or iTunes (PC/Mac) and select your Network Player.
Compatible Streaming Services: Spotify, Apple Music, Tidal, YouTube Music, Deezer, Amazon Music etc.
 USB from my PC or Mac
Any desktop app can also be played from your PC or Mac through a USB connection to your Cambridge Audio network player when a direct point to point connection is implemented.
Connect a USB A to B cable between your PC or Mac and the Cambridge Audio network player and select “USB Audio” as the desired digital input through the network players’ interface.
 Bluetooth (aptX)
Audio can also be played over a Bluetooth connection available by connecting the optional BT100 Bluetooth receiver to the Cambridge Audio network player and pairing it to your smart device.
ui_src_cast_icon.png Cast
If you are using a Cast capable streaming service, you can select the Cast logo and once you select the 851N, all audio from that app will play via the unit.
Compatible Streaming Services: Spotify, Tidal, YouTube Music, Deezer etc.
TIDAL
Please see our FAQ on how to connect via the Cambridge Connect app here.
1 out of 1 found this helpful
