Qobuz Sublime
Airplay.PNG Apple AirPlay
Qobuz Sublime supports the Apple AirPlay service from a compatible Apple device, which allows you to play music through your network player and use the Apple device as a remote control.
Select the Apple AirPlay Airplay.PNG icon  from within the Qobuz Sublime app to select a Cambridge Audio network player on the same network and listen to Qobuz Sublime through AirPlay.
USB.PNG USB from my PC or Mac
The Qobuz Sublime desktop app can also be played from your PC or Mac through a USB connection to your Cambridge Audio network player when a direct point to point connection is desired.
Connect a USB A to B cable between your PC or Mac and the Cambridge Audio network player and select “USB Audio” as the desired digital input through the network players interface.
Bluetooth.PNG Bluetooth (aptX)
Qobuz Sublime can also be played over a Bluetooth connection available by connecting the optional BT100 Bluetooth receiver to the Cambridge Audio network player and pairing it to your smart device.
Select Bluetooth from within the Qobuz Sublime app to choose the BT100 aptX Bluetooth connection.
Chromecast.PNG Chromecast Audio
Qobuz Sublime can also be played via an optional Chromecast Audio (sold separately) by connecting it to the Cambridge Audio network player through the TosLink digital input.
Select the Chromecast icon Chromecast.PNG from within the Qobuz Sublime app to choose a Cambridge Audio network player on the same network.
