iTunes Library
Airplay.PNG Apple AirPlay
You can play music from your iTunes library on your network player using AirPlay from a compatible Apple device.
 Select the Apple AirPlay icon Airplay.PNG from within the Apple Music app to select a Cambridge Audio network player on the same network.
USB.PNG USB from my PC or Mac
The iTunes desktop app can also be played from your PC or Mac through a USB connection to your Cambridge Audio network player when a direct point to point connection is desired.
Connect a USB A to B cable between your PC or Mac and the Cambridge Audio network player and select “USB Audio” as the desired digital input through the network players interface.
Bluetooth.PNG Bluetooth (aptX)
Your iTunes library can also be played over a Bluetooth connection available by connecting the optional extra BT100 Bluetooth receiver to the Cambridge Audio network player and pairing it to your smart device.
Select Bluetooth from within the iTunes player to choose the BT100 aptX Bluetooth connection.
